2011 extended crank time
I'm having an extended crank issue, mostly on cold starts, with my 2011 Silverado. I've replaced the fuel pump assembly, MAF sensor, added fuel injector cleaner to the gas, and taken it to the dealer for a TSB that says to reprogram the PCM for extended crank and alcohol content.
I have access to a Snap-On Modis, and noticed in the data that it shows 60% alcohol content. I have always run E10 in the truck. It still shows 60%, even after having the reprogram done at the dealer. I'm not sure if this could be relevant to the extended cranking.
I'm not somebody who just wants to throw parts at something.  I replaced the MAF because it kept setting a code for it (no longer sets code after replacement), and the fuel pump because cycling the key several times before trying to start it seemed to help, but not totally alleviate the issue. That lead me to believe fuel was leaking back through the check valve in the pump. When it does finally start it misses for a few seconds, then clears up and runs fine. No CEL, no stored codes, shows right around 50 psi every time I have checked it with the key on engine off. Fuel pressure is always right at the desired amount when running. The issue seems to be gradually getting worse. Sometimes it will not start until the second time cranking.
Any ideas?
Any help is much appreciated.
Any ideas?
Need to check the fuel pressure and see if it is bleeding off. That's the first step.
If you don't have one, here is a cheap fuel pressure gauge - http://amzn.to/2AkMgI8
I looked at the pressure with the Modis before starting, after sitting all day. It showed 52 psi but I had to turn the key on to get the Modis to work so I guess it wouldn't be the same as leaving a manual gauge hooked up to the valve on the rail. I'll check it that way and see. If I am getting bleed off, it already has a new fuel pump so I can rule that out, and the filter and regulator are part of the pump assembly.
Why would you rule out the pump. I have installed pumps that were bad out the box several times. What you will need to do after that is pinch off the return and see if it holds pressure. If it does, you will need to move forward. Leaking injector, leaking fuel rail, ect.
Any ideas?
after seeing multiple posts about and just having it happen recently, if you're reading 60% alcohol on e10 that would be the cause unless it does it all the time. does it start normally after its hot? I went from e85 to 87 because I was going on a long trip. when I got there and the truck had time to cool, the hard starts occurred. chalked it up to a fluke but it continued. got back home, got on this site, found a thread with the same issues so the next morning I went back to e85 for close to a full tank and the problem was gone on the next cold start.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,168 Guests (See full list)
