Dtc codes everywhere
000martin
Hey guys I need your help.
My ‘06 GMC Sierra Denali truck is having issues. It started being real sluggish on acceleration and tossed quite a few DTC codes.
All codes have to do with air, fuel, or throttle response and those are:
P0641- 5 volt reference signal
P2101- control module throttle actuator position performance
P0101- MAF sensor performance
P0102- MAF sensor circuit low frequency
P0107- MAP sensor circuit low voltage
P0120- TPS performance
P0220- accelerator pedal position sensor 2 circuit
P1516- TAC module throttle actuator position
P2101- control module throttle actuator performance
P2135- throttle position sensor 1-2 correlation
P0068- throttle body airflow performance
also a couple codes for o2 sensors too rich bank 1 & 2
All this started happening the same day, so I feel pretty sure that it’s one or two issues causing this mess. i am hoping one of y’all can point me in the right direction and thanks in advance.
The 1st code is more than likely the cause of the rest of the codes. Without the 5v reference, few sensors will work - that's the lifeblood of a sensor. What the sensor does with the 5 volts corresponds directly to the conditions it's reading (whether it's a TPS, MAF, MAP, etc..), and that info is deciphered by the ECU.
There might be a shorted sensor that pulled down the entire 5v ref, or, the wiring for the 5v ref from the ECU is shorted, or open, or the ECU itself is bad.
