New member and beating a dead horse
L83_Z71
Howdy everyone! I've got a 2016 Texas edition Z71 with about 28000 and change on my truck. I know it's been discussed over and over again on various forums but wanted to ask for myself about the issue and get y'all's thoughts. So with my truck when I start it up after sitting all night I get what sounds like lifter tick until it's at operating temp. Once I start driving it goes away and never happens again until the next day after sitting all night. My question is... Is it something I should be concerned about as far as my Cam and valve train? Any input is greatly appreciated.
Sent from my Pixel using Tapatalk
Welcome to the forum, I assume you have a 5.3 and yes on an AFM engine it could be lifter tick. Earlier 5.3's without AFM like mine had piston slap noise when cold due to the short piston skirt design. Only thing I might suggest is to drive your Z71 in the Manual transmission mode, if you have the six speed that would be M5. Drive it for awhile that way so the AFM doesn't kick in and see if that makes a difference.
Right but it only does it when it's the first start of the day or the engine has had ample time to cool down.
Its cold and the oil probably ran partly out of the valve train.  My 2008 did it with the AFM.  The lifters are a more complicated design with more moving parts/a big spring thing.  (not the most familiar with the internals).  If youre super worried about it I would see if they can do anything at the dealer.  Or try some heavy Lucus oil for your next oil change.  I've had good luck with it silencing lifters in my old jeep.  Not that it had anything fancy going on.
I'll give it a go here in the 1800 miles. Thanks guys
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 519 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
