engine check light
RP53
strangest thing happened, started the truck and started down the road, looked down and the check engine light was blinking, thought they stayed on if there was a problem, anyway half a mile later it went off, and didn't come back on  has anyone ever had this happen to theirs
thanks
Check your owner's manual. This is from my '15 Silverado manual...
Light Flashing: A misfire condition has been detected. A misfire increases vehicle emissions and could damage the emission control system on the vehicle. Diagnosis and service might be required. To prevent more serious damage to the vehicle:
  • Reduce vehicle speed.
  • Avoid hard accelerations.
  • Avoid steep uphill grades.
  • If towing a trailer, reduce the amount of cargo being hauled as soon as it is possible.
If the light continues to flash, find a safe place to stop and park the vehicle. Turn the vehicle off, wait at least 10 seconds, and restart the engine. If the light is still flashing, follow the previous steps and see your dealer for service as soon as possible.
Regardless, there should be a code stored, so maybe go get that code read.  (don't delete it!) Let's go from there.
well it goes in monday for the steering recall so i will tell them to check it for me let you know what i find out
Although the check engine light usually only indicates a problem with the emissions control system and one of its components, the ECM can interfere with the operations of the vehicle. I keep a OBD2 code scanner (cost me $17) in the truck and now use an iPhone app to translate the codes which give me a starting point for researching the problem. Not at all unusual to find that a code can relate to more than one item and I like to know that to be able to verify when I pick up the vehicle that all the bases have been covered. If the mechanic skipped an area it means a trip back to the dealer to complete the work.
The codes work well with gas powered vehicles with the iPhone app but less well for diesels as the same general error code is used but it means something quite different with the diesel and its very different emissions control system.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 765 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
