2006 Avalanche owner
dna9656
Bought it last fall on my birthday, it had 129k miles on it. I have had some maintenance issues. Changed all the fluids, spark plugs, filters. new tires (all 5) and wheels. I bought Chevy wheels on craigslist, the tires at Costco, I bought the size shown on the inflation decal. I had the transmission looked at, the troubleshooting resulted in a rebuild/upgrade to 4L 65 E from the standard 4L60 E. The rebuilder says vibration over 40 mph is torque converter shudder due to trans fluid coefficient of friction issue, he added a modifier, shudder over 40 mph stopped. I found a seal leaking on the right side of the rear axle so replaced BOTH bearings and seals (R & L) and oil soaked parking brake shoe. I found the left front caliper stuck so replaced both front calipers and hubs, a week later I replaced both idler arms, the inner and outer tie rods too, got the front end aligned. Drives like a new one. I have a shudder/vibration between 30 and 40 mph, I think it's the torque converter, am taking it to the rebuilder Monday. I hate the beverage cup holder in the console, they are too large or not deep enough to hold a cup securely, GM note; good aftermarket item for the parts salesroom. I'd like to know the Recall/TSB status of my truck and the build date and build sheet would be very nice too! Does anyone know where I can obtain such? My truck shows the Z71 option on the Service Parts Identification sticker in the glove box, there are no "Z71" decals on my truck, did this truck ever sport such decals? Thanks to all in advance!
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 805 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
