this morning when I went to drive my truck I got a service stabilitrak notice, followed by a clunk, check engine light, and the dash not knowing what gear I was in. I scanned the code, which was U0101 lost communication with TCM.
I spent some time researching but can't seem to find anyone else with this issue. The truck is a 2014 Silverado 1500 RCSB 4WD 5.3/6L80e. To my knowledge the TCM is now inside the transmission, but not 100% sure. Only 38k miles so I'm unsure what/why/how this happened. Everything has been fine until this morning.
Hoping to get some info here before towing to the dealership.
Yes, the 6L80E is inside of the transmission. If it is under warranty and it should be since the 2014 trucks are 5yr/100k mile powertrain warranty then I would take it to the dealer for help.
  • 10 months later...
Did you ever get any answers? A few weeks ago my truck (14 CCSB 5.3 Silverado) threw "Transmission Hot Idle Engine" and went into limp mode. Since then I've had the truck to the dealer twice, since it's still under the powertrain warranty, and they "cannot recreate the problem" or get the truck to throw any codes. They also can't get the trans fluid temp over 225. Well within a day or two of picking the truck up from the dealer, two weeks in a row, I've got the trans fluid to 243 and 261. Today it started shifting hard and the check engine light came on, it was U0101. Had Autozone print the code sheet so I can get it to the dealer tomorrow.
  • 4 months later...
My truck is stuck in 4x4 for the third time and the dealer just did global resets it worked and then they said not to shut my truck off while I’m 4x4 so I didn’t. But a few weeks ago I turned it on and boom stuck in 4x4 again with service 4x4 display. The dealer is now saying it’s the tcm and that it isn’t covered under warranty ? Sorry I can’t afford $1000 them they say something about a purge switch and they’d fix that for $450 I said no thanks it doesn’t seem like you guys are sure on what it is. Boom they say ok you owe us $109 for diagnosing. I’m confused if they aren’t sure what it is then how do I owe them for a diagnosis. I need help please
Any issues with the 4x4 yet?
  • 1 year later...
where is the tcm location. mine gets stuck in low just had a brand new tranny installed at dealer and the refused to put it under warranty. 2014 silverado 1500 4x4
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
