Front End Vibration Again...
So now somethings up with my truck. Noticed a vibration doing 65-70 Sometimes at around 60. I ruled out my rims/tires just got them, balanced them out everything and rode fine. Ball joints tierods, contol arms are still good. Did the both front wheel bearings during this past summer. One thing is that my pitman arm looks and feels loose as in when I pull and push the tiers back and forth while its jacked up I can see it move and it clunks. You guys think that could be causing it? It vibrates a good bit.
Probably pitman arm, tires could cause a vibration too. How did the road force? Even if they balance good, they could still have a bad road force measurement and cause a rough ride.
Im not gonna lie, I just saw when the machine showed "zero" im not to familiar with how the balancing and road force works. One thing I forgot to mention is that I feel it more on the drivers side wiich is were the pitman is. Gonna go back tomorrow and ask them about the road force and see about replacing the pitman. Thanks for the reply
