Driveline clunk maintenance..2008
After reading many threads about the standard Chevy issue driveline clunk, I went about doing the maintenance to stop it.
I took driveshaft out. U Joint strap bolts were tight, but not loctite tight, so that was nice, in 34 degree weather..
The first thing I noticed, the yoke was filthy with black grease/antiseize type crap.
So, being a gun guy, I cleaned the crap out, dried it, used emery in there to take down burrs etc. Then I put a couple piece of rubber to act as cushion, if that really does help. And, Liberally applied Mobil 1 red synthetic grease.
Tightened everything back up. And drove. After 20 miles, stop and go, its very quiet.
Very sad we have to do maintenance on something like this due to poor engineering.
What do you drive?  What & where did you apply grease?
3 minutes ago, Steve40th396 said:
I put Mobil 1 grease inside front yoke that slips into transmission, along with a couple thick pieces of rubber hose.
2008 Silverado 1500 2 wheel drive Z71 Crew Cab
Good to see the clunking went away.
You say there was gunk on the spline.  Does that mean a remedy had already been attempted?
If the clunking comes back, may want to replace the yoke.  If memory serves, there's a nickel plated upgrade that is supposed to fix this condition.
Supposedly its a TSB from gm to grease the inside of the yoke to subdue the clunk. Others have put rubber in there too. I think its to ensure yoke doesnt slam into transmission output shaft. Dont think it ever does. That would be a serious issue gm would have seen years ago.
Some have more faith in what GM sees, than others.  Enjoy your clunk-free driving.
If it comes back, I will regrease it. Simple process. I am not really looking forward to spending money on a plated yoke.
I mean, I can have it plated too. But, if it comes back, I noted the mileage, and I will just do it as necessary.
Again, only from memory.........
There was worry of the unintended consequences of introducing foreign substances  (such as grease) that could find it's way to the ATF, however unlikely.
The transfer case yoke you can not use grease.. Mine is attaching into trasnmission, 4l70E
That sounds right.  Thanks for clarifying.
Looks like some folks beat me to the reply about only using ATF to lube the slip yoke.
Question about your rubber spacer--what was the dimension of the spacer you inserted?  I'm wondering how much is enough--but not too much--to prevent binding.
I put a 1x 3/8 piece of fuel line in there.. Just a piece that will act as some bumper effect if the yoke actually ever goes that far, which I honestly dont think it does. I think there is slop in rearend and transmission, and we hear it and feel it. You can move the rearend pretty easily by twisting the driveshaft when on jacks. Now, add 5000 lbs of weight etc. Maybe one day I will mount a go pro down there and watch it.
could you avoid the clunk by accelerating slow enough? mine has a bump on acceleration but if I take off slow enough it wont do it and then I can accelerate as hard as I want to. Ive gotten used to it and just accelerate slowly but it is super annoying
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
