Instrument cluster
Chfc2
Hi there , Just picked up my 2018 Hd and need to know what the number 1 means all the way over to the right near the gear selector.  Thanks in advance for any help
No it's not lol.  It just locks the trucks transmission into first gear and won't let it upshift.  If you select that 1 position at highway speed you get some really aggressive engine braking as the truck will do what it can ( without over-revving) to get into first.  That's it.
Easy way to see... just try it lol.
This.  Except when you put the selector into that "notch" you can change this number using the "+/-" button on the shifter.  But beware it is NOT designed to be used like a manual when you are in this mode.  It just limits the highest gear that the truck will shift into.
Incorrect.  On a newer HD you have PRN DL 1.  L let's you shift max selected gear.  When you shift to that 6th position that says 1... It's 1st only.
Correct -- I forgot we were talking about HD's instead of the 1500's   :sigh:
    liddlera
    liddlera
  • Who's Online   1 Member, 0 Anonymous, 352 Guests (See full list)
