Correct years?
MHPrior80
I can’t seem to find it for the life of me but I’m looking at suspension lift parts and I see that some say they work for 14-18 model silverados and I also see parts ( knuckles especially ), that say 07-18. What is correct exactly?  I would think it’s would be 14-18 but I know some times some parts just don’t change either. Thanks everyone
Buying individual parts would be done differently then whole kits. Some parts have just never changed much and can be used for a bigger span of years. When it comes to a whole kit if any part is specific for only a few years then they have to list it for those specific years regardless if some parts fit years outside of what they say.
Should do spindle if you're 2WD.  CST is what I'll be going next year when I upgrade to 34s.  It will be the same across the board for years.
The spindle alone gives 3.5".  If you have any level/spacers already installed, that adds to the 3.5".  You will have to get leafs or blocks for the rear though.
http://cstsuspension.com/steel-upper-control-arms/206-lift-spindle-kit-2014-15-1500-2wd.html
Yep that’s what I was looking at. Didn’t
wan to say knuckle. Meant spindle. I seem to find some that say 14-18 years and others that say 07-18 years for spindles. Just wanna make sure I’m getting the right parts is all. As for the rest I’m doing a 4” rear loft block. Basically I’m looking at a 5”/4” lift by the time I’m done
After a lot of research I decided to get the Rough Country 5” suspension lift (2wd) without the shocks/struts for now. I have rear shock extenders for the time being till I do my research on shocks/struts down the road.
    Aries68
    Aries68
  • Who's Online   1 Member, 0 Anonymous, 305 Guests (See full list)
