fixer-upper Z71
Hey guys, just bought a semi-rough 2003 Suburban Z71 4WD. Seems to have alot of options, I have papers on it having the trans rebuilt last year which is nice. Needs pads, rotors, and tires. Took it to get the check engine light and got this list:
U1000-Class 2 data link malfunction
U1255-Class 2 communication malfunction
C0300-Rear Propshaft signal circuit malfunction
C0305-Front propshaft speed sensor system malfunction
C0306-Motor A/B circuit malfunction
C0321-Transfer case lock circuit malfunction
C0327-Encoder circuit
C0359-4LO discrete output circuit malfunction
C0374-General system malfunction
C0379-Front axle circuit malfunction
P0141-Oxygen sensor heater circuit bank 1 sensor 2
P0154-Oxygen circuit activity detected bank 2 sensor 1 intermittent
P0155-Oxygen circuit heater circuit bank 2 sensor 1
P0161-Oxygen sensor heater circuit bank 2 sensor 2
After some googling, looks like all the "P" codes and C0300 are all oxygen sensors that probably need replaced. After that I'm unsure of the rest figuring out what actually needs to be fixed. Any help guys? Thanks in advance! Nice to be here :)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
