Newbie from Texas hill country
ucwinters
Purchased a 2018 Chevy 2500 HD LT Duramax last week - selling our motorhome and getting another 5th wheel RV.  Have owned a Powerstroke and a Cummins in the past.  Last GM product for me was a GMC 1/2 ton truck back in 1992 (wife currently drives a 2016 Chevy Camaro RS).  Looking to learn a little here on the forum and thanks for letting me onboard!
Ed W.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 509 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
