Fuel Injection
monkey2002
Good afternoon,  I have an issue with my 2002 Sierra 2500HD 6.0L.  I recently replaced the fuel injectors, fuel rails, FPR, plugs, wires and coil packs on all 8 cylinders.   Before I was having miss fires on # 6 while pulling hill on highways and towing my travel trailer.  That is why I decided to do a tune up.  I have only owned the truck for a year and had no idea when or if any of those parts were replaced so I thought it was a good idea.  However after I replaced all those parts I was having an issue starting, I play around more and noticed that the FPR vacuum hose had a small crack in it, so I replaced.  That solved the issue upon a cold start, it fires right up like normal.  However when engine is a operating temp and I try to start it, it has a long hard start.  I found if I cycle the key a few times it starts easier but still a longer than normal crank.  I'm looking to see if anyone has had this issue and found a fix before I spend a lot of money a dealer to solve issue.  Thanks in advance.
I do not know when they moved fuel filter to inside the tank, but, if you have an external fuel filter, replace it.  Also do you hear the fuel pump when you turn the key on?  How long does the pump run?  The only thing that happens with key on- engine off is the fuel pump precharges the fuel rails and pressurizes the system.  Perhaps the pump is not running long enough to do this in one cycle.
Not sure if it does have an external or not but the not thing that gets me is I never had this issue before I replaced everything.  Just seems odd to me
Stick the old fpr back on.  What you describe, especially the key on 3 times before it will start leads towards fuel.
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
    • It’s at the point of amusement. I’m retired I have time. It’s fun seeing people try to convince me I’m using oil. I’m buying oil at the prescribed time. It gets drained and new goes in. Do I add in between, no. My oil doesn’t even get dirty in 5k miles. I don’t even see any drop on the stick. I check in the same place. All is well.
