front end knocking
2006 Z71 here. I've started to get a knocking sound from what sounds like the front drivers side during a slight turn to the right. You can't feel it in the steering wheel but you can on at the pedal and you can hear it. However it only seems to be when its cold. Once it warms up or you have been driving for a while it goes away. I've checked the front drivers wheelhub and its tight..no play. I've looked at the rest of the suspension partsand they look fine, even changed the sway bar links just in case. The I-shaft is tight also with no play. I also changed the brakes but this was happening before then. suggestions? oh and new shocks so those are good and tight.
i double checked the hub and there is zero play in it. I did notice some play in the pitman and idler arms, could that make a knocking sound with a slight turn of the steering wheel?
CV shafts maybe. I'd check 100% of the steering and suspension thoroughly. Check the left side, not just the right
Check your torsion bar bushings. Right under the drivers door. Grab the torsion bar and shake it up and down. Shouldn't move at all. I have replaced a lot of these. I just helped a guy on a different post with this. Let me see if I can find it.
Here is the Part you need if it is the problem. http://amzn.to/2HCzqaC
Here is the other post. http://www.gm-trucks.com/forums/topic/209239-bump-in-drivers-floorboard/?tab=comments#comment-2082556
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
