Outside Heated Mirrors
Hi guys!
I own a 2002 Silverado Extended Cab LS 5.3 Z71
Someone busted my mirrors on my truck so I ordered replacements.
The replacements are "Heated" versions.
My truck was not ordered with heated mirrors or rear defrost options (though research states that all 2002 1500 trucks above WT model came equipped w/Heated mirrors).
I'm thinking about ordering a new Blower control Unit that Does have the Rear Defrost button (that my control does not).
My question: Does my 2002 Silverado have the wiring (plug and play) already present in order for the new Blower control (Rear Defrost Button) to function (Turn on the heated mirrors)?
I know that I can run my own wiring, but would like to avoid that if at all possible as I really like that Factory look and function.
Thanks for any help.
  • Doren Martin changed the title to Outside Heated Mirrors
7 hours ago, Doren Martin said:
Hi guys!
Unfortunately now. I just looked you a 2002 Silverado mirror connector and it gives multiple RPO codes.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
