2014 Silverado 5.3 P0300?
jrob56
Hey guys,
Yesterday running some errands, I was down on power and CEL started flashing. Killed the truck started back up and ran perfect, happened one more time and I swung by autozone because I was close. P0300 showed as pending, not set yet though.
I have been running E85 mostly lately, tank of 87 here and there. Had a full tank of E85 in it at the time. I have occasionally had some hard starts, 3-5 second crank before start. I dropped it at the dealer to take a look and they said it has run great for them. Freeze frame data though showed some o2 readings off. Pass side upstream o2 reading was off and they said that can cause it to over fuel. Both rear o2 readings were out as well. They want to replace all 3 but said you could start with front only. Want 270 for front o2, diagnostic and labor.
Does this sound like it could be the issue? I have not really heard of intermittent o2 issues. In my past experience they were good or bad and threw an o2 code.
Thanks,
Josh
You need to find out which cylinder has the most misfires first. If one cylinder isn’t significantly higher in misfires than the other, I would look at O2 readings while burning 87 octane. Make sure the vehicle is warmed up and in closed loop before checking.
They said on 4 and 8. Its just odd they cant reproduce if that sensor is bad. I feel like they are throwing parts at it, and want 90 for diag, 120 for the o2, and 60 labor and taxes. That is almost 3x what the part seems to be online. Think Im going to get it back and drive it some more. Going to have to pay that stupid 90 diagnostic anyway though..
https://www.rockauto.com/en/moreinfo.php?pk=6309813&cc=3294345&jsn=12&jsn=12
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 888 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
