Axle Seal
Have '10 Tahoe and '05 1500.    '10  axle seals went at 50k miles.    '05 1500  has 130k on  it. just changed the oil in differential few months back.  In October it started to leak.  its axle seals.     so looking in to  if they make a better seal?   I would think on the '05   are  the original ones.  .  thinking might as well get same Acdelco ones if there is not a better product out there.
