2018 Silverado 1500 Front Bumper Face
So I bought this here
http://www.ontariomotorsales.com/new/vehicle/2018-chevrolet-silverado-1500-wt-id8439692.htm
I want to make the matte black bumper face a glossy black like the rest of my truck. What are my options? What do you think is most costly? Buy, vinyl wrap, plastidip?
If buying one is my option where can I get one? My GM dealer?
I couldnt find anything in search so sorry if this has been covered.
Thanks guys.
Bumpershellz makes a 3 piece cover that goes over the bumper, I've not experienced it first hand but it seems like it might be the cheapest and easiest option.
You could vinyl wrap it, if you are good with vinyl it shouldn't be too expensive. If you have to take it to a shop to have it installed the labor could get pricey, depending on your local rates.
Finding a bumper off of a wrecked truck and replacing yours is a good option, but it is probably going to be hard to find.  You could buy a new bumper and have it painted from the dealership, but don't expect that to be cheap. A dear ran into the front of my truck and a new bumper was $666.20, before paint. They had to paint the bumper, grille, and fender and paint cost around $1,100.
I would take bumper off and have it painted and cleared by good body shop...
Make a few calls for pricing, but get heavy clear coat to help protect from rock chips..
My 2016 RCSB connected with 200lb buck for $12K damage and original bumper was "factory" flat black.
Requested dealer body shop paint gloss-black with heavy clear on replacement bumper..
Now, it looks great and will probably last longer,, unless another buck finds me..
Cheers---K
Thanks guys.
Welcome to this forum!  Get a few quotes from local body/paint shops.  If too expensive,  follow adamj2121's first tip!  I'd like to see a picture of your truck because I think factory flat black bumpers have a great look!
Cheers---K
Thanks for this! This was very helpful. I have the exact same model as yours, just newer. After seeing the picture of your truck I think this may be the route I'll take, it looks nice. Helps when you actually see it.
Sorry to hear about your truck! Let's hope that never happens again haha.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 585 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
