Shock Confusion
I have an 04 Avalanche 1500 2wd with a 3" lift.
I need new shocks but cant find any Fox shocks for an Avalanche 1500 with a 3" lift.
Can I buy shocks for an Avalanche 2500 with a 3" lift (Fox product number: 983-50-007) or will it not fit?
Sure. With some fabrication. I just got off the phone with a Fox dealer.  (Carolina custom trucks - 843-664-2414) And he said they don't make them for the avalanche 1500's
He said the only thing they show are the sky jacker for the avalanche.
Here they are. https://amzn.to/2qEq2go
