Steering Stabilizer
Can I put one on my 2016 truck with the digital steering assist?  My understanding is the bracket is no longer there.  But is there an aftermarket one that will work still?
Yes, BDS make one that I had put on my '16 with no digital steering. Don't know if the digital steering makes a difference or not.
Hmm.  Not sure.  Someone told me that some electronics are in the way if you have the digital.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
