Towing and Payload help
I have an ‘04 Silverado 1500 regular cab stepside 4x4, 4.8L V8. Does anybody know what the max towing is for that configuration? I believe the max payload is 1,275 lbs. My truck has a 3” body lift and the original factory installed trailer hitch receiver, if that affects anything.
I’m not a towing pro, but I would like to know if it can handle a sedan weighing less than 4,000 lbs. Below is a picture.F1AE21D1-6332-487E-AB98-0E5E7356730B.thumb.jpeg.17d89e341ab812b8cabd664ed153ea53.jpeg
