07 Suburban, 215k, AFM delete kit installed with new Oil Pump (Mellon M365), new Oil Pressure Switch, oil screen removed, new O-ring and a L92 Valley Cover.
So when the truck is cold the oil pressure is about 55psi, once the truck reached normal operating temp, the oil pressure drops to just below 20psi.  It stays about 20psi when the truck it at idle or just above when at 2000 RPM.  I do not hear any ticking sound when the truck is cold.   It throws a code of P0251.
Possible problems
1.  O-ring may have been installed incorrectly,
2.  Oil sending unit might be bad
3.  Oil relief valve in the pan might be stuck.
Any help would be great.
  • 2 years later...
Possible problems
Honestly man, if you do not hear the ticking on the driver side you are in good shape. My 1500 (2012) has always struggled with "low psi" at idle, around 20 psi, and I have not had any issues. Now, my 5.3, like many 5.3s does eat oil but that tick is a dead give away when it needs more. I have had experience with the sending unit and replacing it. Unless your oil pressure is dropping to zero that is likely NOT the problem so you can take that out. Which is a good thing for you because that wiring harness gives such little slack that getting the new sending unit installed is a pain in the butt. I am curious, just check your oil and see if it has the full 6 to 6.5 liters in there.
On 10/10/2020 at 1:25 PM, jackmac said:
Did you find your problem? I have one doing the same thing. Thanks
What steps have you gone through to diagnose your issues? Maybe I can help.
Thanks for the reply jfath14,  I have checked with a manual gauge at the port on the front of the block ,cold start it will read 45 psi and slowly start dropping to  around 11 psi hot, gauge will respond quickly when engine rpm goes up. 1000 rpm it will raise to about 20psi when hot. Now with the manual  gauge on the sending unit location 28psi cold and slowly drops to   5-6 psi hot and barley hits 10 psi at a 1000 rpm. No engine noise .   The strange thing is literally the day before it done this I had 40 psi cold 28-30 hot but would go to 40 again at 1000 rpm. overnight it changed. I have done a VLOM mod where I block the oil passage to the solenoids and cut the tower gaskets and turned off the AFM with a HP tuner. I have done this same mod at least 20 times and never had a oil pressure issue so I'm thinking it is just coincidence it happened after the mod. ??  Could the pick up tube O ring do this or the AFM pressure valve in the oil pan? Thanks for any insight you have.
What is the exact model of your GM?
2 hours ago, redvett said:
P0251 does not apply to a gas engine only a Diesel.
I saw that and thought that was an odd code so I just left it alone. Maybe a typo.
What oil filter are you using? I ask because I had a mobile1 for a while and over time and the pressure was dropping gradually. I switched to a fram and it corrected the problem immediately. It sounds stupid and I was skeptical at first but it made a difference. Do you have any leakage around your oil coolant lines? (Inside driver side front wheel under the block) That is a common place for some oil loss and compression issues. I would also urge you to check how much actual oil you have in the engine. That engine really does devour oil the older it gets and anyone who tells you anything else has just gotten lucky with the engine they received. ESPECIALLY if they still have the AFM active. That 5.3 will burn oil every single time it switches from V4 to V8.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
    • Engines wear. It is unavoidable. So the question isn't if it will wear out but rather WHEN it will wear out. That question is about rate and RATE is a HUGE problem for almost everyone; but not in the way we may think.    Unless there is something drastically wrong with your powertrain, wear is exceedingly slow. It doesn't wear out in minutes or hours or days or months but in years or even decades. Ditto sludge and varnish. Humans are an impatient lot so to see the benefit of a truly superior product you may have to wait a very long time. Most will get bored first and trade before they reap the benefit.   Humans are not companionate creatures when it comes to those we do not know. We don't care what happens to the second or third owner as long as it doesn't happen to us or someone we know and actually like.   Sad commentary on humans but it is what it is. That thus, then, there is no advantage...to or for you if the above paragraphs adequately describe you.    BUT if you are a buy and hold type and patient enough to reap the rewards of your labors then that thing that is happening that you haven't yet seen, but will; can be abated by such products. Seals harden and leak with time and lots of it. Rings stick after thousands of miles of a slowly building plaque of varnish.    Then there is this. This didn't happen over night and this poor fellow knew when he removed the cover and not one second before.   Not "aware' isn't the same thing as "isn't happening".        The above was typical of the Ford 361 and 391 bus motors on Bulk Pennzoil Mineral Oil products on 3K mile OCI's at about 60K miles back in the 60's and 70's at the Anamosa School District when my Uncle took over their maintenance program.    This is Pepper at @ 165K on 5K OCI's using Group IV/V Full Synthetics.      HM oils will help the first but not the second.    Then again if one used..... ah, ya know.....
    • Thanks for coming back with an update.
    • Awesome you got it sorted! That's a new potential issue I'll have to mark in my book of issues. Thanks for the feedback.
