Finally found the right pressure washer to go with everything and tested it out tonight. I think I need more soap next time, the foam didn't stick very well, ran off in a couple of minutes. Used about 3-4 oz of CG honeydew. Will try more next time!
What brand is the foam cannon? I also got a electric pressure washer and it seems like it doesn't have enough power to make the soap foamy so it'll sick to the truck. I've thought about buying a gas pressure washer but the electric one fits my needs just fine.
Sent from my SAMSUNG-SM-N920A using Tapatalk
It's a knock off chemical guys cannon, made by dusichin
Because thr truck was probably wet before you foamed it.
Trick is spray the truck just with water first.  To get all of thr big debris off.  Let it dry.  Then come back with the foam full blast
I'll try this next time, thanks!
Wash, clay, and wax today. Not sure if I'll get a white truck next time around, the little yellow bird poops stain the paint and don't come out without a good scrub of a claybar or scratch compund.
Youll want to stick with white. It shows being dirty less than anyother color
If you prep and seal your paint properly, stuff like that will come right off
Any steps I should add into the detail above? I'm just getting into being able to detail myself, so still learning.
I carry a can of cleaner in my truck with a soft rag for bird poop, they sure do love a clean blue canvas. But if left in the heat it doesn’t take long for it to etch the paint
Depends how long you want to spend outside
I would wash the truck.  Then detontaminate the paint with irox x (if youre not in the sun on a cool day you can clay at the same time)  risne very very well.   Put a good sealant down (twice) do that every other month.  Youre set
So you'd prefer a sealant over wax? I'll look into some sealants, never really looked into them before
Sealant lasts longer.  Idont use wax anymore
A sealant i like to use on my white truck is white light from chemical guys. I do 2 coats.  Or i use sonax polymer net sheild
Waxes to me are useless
This is a good idea that I'll probably start doing. The truck is only outside from about 5pm-8pm at night and 6am-7am in the morning. Small window for the birds to get it, but they never seem to fail! Lol
Good to know, I'll look into them. Thanks for the tips!
  • 4 weeks later...
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 495 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
