Is it possible.to add power adjustable pedals to a 2018 Silverado LTZ that already has memory seats/mirrors?
I'm assuming I'll need the entire assembly, wireing harness, and new buttons where the console is. Does any programming need to be done? Is this even possible?
Also, do the adjustable pedals retract further towards the firewall than the stock position of non-adjustable pedals?
I'm looking to retract them further in because after owning the truck for a month my right foot is a little cramped from the current angle.
When I performed the Seat Memory Integration, part of that was gaining pedal adjust memory. I already had power adjust but wanted to gain memory recall.
Didn’t know you could get an LTZ with Seat Memory and no pedal adjust.
What I learned is that the way the pedals actually adjust are really different in trucks with seat memory versus trucks without. On seat memory trucks, the power goes from the X51L Fuse Block -> Seat Memory Module, then the commands from the Seat Memory Module -> to the pedal adjust motors.
On trucks without Seat Memory, it goes from the X51L Fuse Panel -> Pedal Adjust motors.
So the “flow” of power go in opposite directions between the Seat Memory versus Non.
Not 100% sure if this helps at all, but from the sounds of it, there will be additional wiring from those locations and their destinations. I don’t recall seeing any BCM interface and don’t think/know if any programming would be required.
I have one of those LTZ trucks with memory seats but no adjustable pedals.  I'd actually rather have pedals vs seats
My Sierra has the adjustable pedals, but I have not tested how far they go back into the firewall. If you can get me a baseline measurement for non adjustable pedals, I will fully retract them and measure to compare them.
  • 2 years later...
Hey Phil,
So if I have a 2015 Z71 with no memory seats but I want to retrofit some adjustable pedals, from what you're saying I assume all I have to do is install the pedals to the new switch panel (that will include the switch itself on the switch panel) and run it to the X51L fuse block?
I looked at the Adjustable Pedal schematic (it states without A45) and it appears that the Instrument panel Switch and the Adjustable Pedal Motor runs to the X61A junction block which then runs to the X51L fuse box, which also connects to the K9 Body Control Module and then to the B81B Park Position Switch.
Am I looking at the correct schematic? am i even correct? lol!!
Looking to upgrade the pedals since my wife is 4'11" and she wants to pedals to come up.
Page 3
https://www.gmupfitter.com/files/media/photo/578/Sierra_Silverado_Electrical_Body_Builders_Manual_Service_Manual_2015_en_US.pdf
Edited by BlkZ71Rado
Can’t load the PDF, but you’re in the right track. My truck didn’t come with A45 but had adjustable pedals. So you should be able to add it. Just double check the driver side fuse panel panel for the relays (they might me onboard printed relays and not typical block style relays). Add any missing wiring from switch to pedals, to X61a Junction box, and the fuse panel.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,218 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
