Black Exhaust Tip Pictures
ray2005
Looking for pictures of black exhaust tips. I have a black Silverado and am debating whether to stick with chrome tips or give black a shot for a more subtle look.
Sent from my Pixel 2 XL using Tapatalk
2016 Silverado LTZ w/ NHT.
  • 3 weeks later...
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 158 Guests (See full list)
