2007 Silverado 1500 W/T 4.8 automatic regular cab long bed. Just bought this 2007 from an auction. 170k miles. Trucks runs and drive great but the service brake booster message comes on and stays on when you start the truck. I tried pulling codes with my reader and there are none. This must take the TechII ready that pretty much no one can afford. I dont want to run out and replace the brake booster if that not the issue. Any ideas?
I would start by checking the brake fluid levels, check ALL of your in cab and under hood fuses, and confirm that your vacuum hose to the booster and / or vacuum pump are working correctly. If that didn't fix it, I would start Google'n the issue and posting in requests for info in forums.
All fluids are good. I spent a couple hours googling the issue. Nothing helped. Nothing clear. I learned that pretty much everything but a bad brake booster will cause this message.
    Interestingly enough, because of a website clerical error, you would get paid $11.27 for every one of these that you buy, via rebate: The rebate exceeds the cost of the part.
Cardone 54-74833 Remanufactured Power Brake Booster
Was: $51.29
Price: $48.73 Free Shipping for Prime Members
You Save: $2.56 (5%)
Post-purchase rebate: $60.00 Rebate forms
Price after rebate: ($11.27)
Edited by starman8tdc
9 hours ago, starman8tdc said:
$48 with 2 day shipping included. Verify fitment prior to purchase.
Except if you google the issue. Everyone says that "Service Brake Booster" will never be triggered by the brake booster. I have no issues replacing it if it fixes the problem. From everything I read there is nothing in the system to actually check the brake booster. The message is porely written and points to other issues.
It may not solve the problem, but its free to try. Better than free. You profit over $11 just by installing this on your rig. The rebate exceeds the cost of the part. I don't think it will solve the issue, but if your getting paid to replace it - why not give it a shot?
Do you have a vacuum pump mounted on the booster and a hose going to the booster? If so the pump may be bad. Thats the only way the cluster would know the vacuum is low in booster.
nope. Hose coming off the back of the engine to the booster like most gm trucks.
It a know issue when power steering is low, or the cluster has been changed. There are several service bulletins about different things causing this issue. From spending a few hours in google its pretty much a guarantee its not the booster.
12 hours ago, starman8tdc said:
Did you already try disconnecting the battery for 30 minutes with the ignition on?
Yes. Over night. Message went away and came right back.
Turns out the transmission is shot. The message was gone until I got on the highway and truck tried to go into 4th. Its trashed. Seems clutches in 3rd and 4th are no good. I am keeping my fingers crossed that rebuilding the tranny will make the message go away. Not likely but hopefully.
10 hours ago, starman8tdc said:
Dude, don't drop thousands on a trans. You can replace the truck cheaper than the trans. Junk yards will sell a trans for 100, and you can get it installed for 300.
I paid $1400 for the truck. A tranny from a junk yard is $800 + more for shipping for a 2007. Its a one year only transmission. I can install it. Did two last week. I will buy every 2007 you can find me that kinda runs and drives for $1,000. Book is $7000. I will sell it for around $6000 with a new tranny. Its very much worth fixing. Please... find me a couple dozen 2007 Chevy trucks for $100 each. I will gladdly pick them up pretty much anywhere in America, fix them and make $6000 a truck.  No one ever mentioned thousands for a trans. Its only $1200 full warranty with stronger then factory parts and my guy is taking it out and putting it in. Freeing me up to work on something else. That puts me in the truck for $2700. Low trade in is $3200.  Around $2500 profit for a days work.
Ah. Sounds like you know what your doing with vehicles. Most people drive to the dealer and say "please fix what ever is wrong with it". The dealer would probably be $3,500+ to replace the trans. There was a post a few days ago where a guy paid the dealer $2,700 to fix a water leak from a window gasket.
I'm working on a 2008 GMC Sierra 1500 today. Rod knock.
 As for part pricing:
http://www.picknpull.com/part_pricing.aspx?LocationID=136&NavItem=0&SearchCriteria=transmission&#partpricing
    DM22
    DM22
  • Who's Online   5 Members, 1 Anonymous, 2,187 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
