https://www.safercar.gov/staticfiles/safercar/pdf/EA11-001_closing_rpt.pdf
I found this picture by accident after three hours of searching for a picture of the routing for the steel lines for my  2006 GMC Sierra 4wd.  Most other GM trucks would be the same or very similar.
I cannot find a way to post just the picture.  Open the link in Adobe Acrobat and go to page 14.  You can blow up the picture in Acrobat, around 300 % gives you a clear easy to read picture.
lines run in order, from inside edge of frame (in plasic clips) or top edge of frame (in plastic clips) outward or downward.   If you run your lines in this order there is no crossing or bending of lines necessary.
Antilock brake ports:
1. top center port to right front brake
2. top left port to left front brake
3. top right port to rear brakes (actually, this line runs in it's own clip
4. bottom left port to master cylinder rear port
5. bottom right port to master cylinder front port
Thank you Joisey for posting this. I had the brake line rust through going to the right front last week. 99 Silverado 2500 (no HD), that I had bought in 2010. While replacing the line I noticed 3 other brake lines had already been replaced, which kind of surprised me a bit, seeing very little other rust under there.
It wasn't a fun job for sure, doing it on a creeper, with no lift. It was equipped with standard 1/4 inch tubing, but of course the flare nuts GM used are different from the flare nuts that come on the tubing that you find at the auto parts store. They did have the correct flare nuts in stock, I just had to cut the tubing to install them and re-flare them again. I had a double lip flaring tool.  I came straight out of the ABS controller with the new line  and ran it along the inside of the frame, ( it came from the factory coming out of the controller and going to the outside of the frame rail) and then pretty much routed it the rest of the way as it was from the factory.
I tried gravity bleeding the system first. When that didn't work, my wife helped me bleed them and now all is well.
I know I might have found the lines at the dealer with the correct flare nuts but I've found your usually better off in the long run not going there until your forced to.
I'm glad that the diagram helped you.  I used the FineLines replacement lines the first time.  My original lines lasted 84K and I replaced them when they began to weep.  The FineLines lasted 36K and rusted thru.  My current set is made by Dorman and is stainless steel.  Fit is excellent, but I will never know how they last because the truck is going down the road.  Enough is enough.
Again, I am happy that the diagram helped you.
     I usually just leave the old lines in place, and run the new lines along side them. You can spray the new lines with rust inhibitor once per year to keep them from rusting out.
      To post the picture, try this:
      Get the image on your screen, and then hold down "Control" and press "print screen" - which is located to the right of F12. Then open Microsoft paint, and select "Paste". Now just save the file to the desktop, and upload to the site.
I undercoated the first set of FineLine "lifetime" brake lines when I was sure there were no leaks.  Four years later they ruptured at the weld line.  One front driver's side and the main line feeding the rear brakes.  GM said there is no trouble with their brake lines, but on new trucks they are plastic coated, just like the two lines going to my rear wheel cylinders  on my 2006 Sierra.
I would have tried the 'print screen' idea, but alas, I have no MS paint.
   Assuming that you have a smart phone, you could screenshot it and upload that way. Or take a picture of your desktop computer using the phone, and upload.
      If you right click on this image, you should be able to save it to your desktop. Then you should be able to upload it to the server.
Edited by starman8tdc
Does anyone know the connector (nut) size that connects the brake line (right front) to the ABS module? 99 silverado 4wd
Edited by Jfayadjr
I replaced almost all my lines with nylon-coated pre-bent steel lines from GM.  Still look good after 4 years and about 50k miles.  Only dumb thing about them is that GM didn't include the 2 lines going across the rear axle and they don't sell those lines separately anymore either...
It's a 5/16 to 1/4 reducer,brass,all parts stores have them,this way a 1/4 " line can be used with out touching the flare
  • 8 months later...
I have a 2006 GMC Sierra 4 x 4 Crew cab SLE. My lines are the tc04 727. They DO NOT go into the ports like everything I've seen says. The only diagram I gave found is from dealership or nemigaparts. It does not clearly show proper routing/port locations. I'm at my wits end here.spacer.png
I know from the only color code left my Rear Master cylinder line goes into the Top Middle port. I also know the line running to the rear (drums by the way) goes into the Top Right port. I am also fairly confident the Left front (Driver's side) line goes into the Top Left port. Other than that....HEEELLLLPPP!
Edited by ChrisMatthews
Addional info
That would be your best bet.  When I did my lines years ago, I made sure to take pics of line routing (particularly along the frame rail from the front wheel to the abs controller, but also if it goes over/under various bits).
And be careful with the various clips holding the lines in place, as at least some of them are NLA new, and are very difficult to remove from another truck (say, in a junkyard) without also breaking them.
Thanks Dave. Clips were pita, but patience and determination won in those. I took pictures, lots of them, trouble is the lines twist over the frame by the firewall. Also the pictures I took help quite a bit, however it only takes 1 out of the bunch to mess you up. I planned on paying close attention near the ebcm, but the lines snapped like dead branches. Looked at several trucks, all a bit different. I did gain perspective on the lines going through the clips though. Haven't yet determined if that helps me or not yet.
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 3,021 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
