Rear end clunk
Hi Guys,
New to the forum here.
I have a 2017 Silverado 1500 Z71 Redline Edition with 11k on it. Recently I noticed a clunk in the rear end with turning in reverse or in drive at low speed. It almost sounds like the exhaust is swinging side to side. I took it to the dealership and they said the leaf spring needed greased but after they did it the sound was still there. I took it  back and they replaced the leaf springs and shackles with brand new ones which helped a little but the noise is still there. They tried pulling the ole "every new silverado does that and this is common after the vehicle breaks in" trick but I'm nearly certain that is not the case. Has anyone else experienced this and what are some options/fixes I can do incase the dealership won't try to fix it (sounds like they wont)? I hope this post is in the right section and I appreciate any feedback. Thank you.
3 hours ago, starman8tdc said:
How much have you spent so far, including diagnostic time?
It is all under warranty so I haven't spent anything in terms of money but my truck has been in the shop for 2 whole business days now between both trips.
Some threads on this. I bought my 15 new I have given up on trying to “fix” this noise and have learned to live with it. I live on gravel so greasing isn’t a option for me. Lots of these trucks out there now with 150k miles on them and I haven’t read about any spring failures yet.
Mine just starting doing it at 10k miles, they will blame my 2 inch drop shackles im sure so i aint bringing it in unless I get ambitious and swap shackles again
Most likely. I have a RC leveling kit on the front installed by the dealer and the first thing they tried to do was blame it on that.
    B07
    B07
  • Who's Online   1 Member, 0 Anonymous, 729 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
