28 minutes ago, dave_clt said:
Seeing this post reminded me of a question I've had... is truck stop diesel the exact same Ultra-low-sulfur diesel you get from the 'standard' non-truckstop diesel pumps needed for our trucks?  My googling the question didn't get an exact answer other than sometimes it's taxed fuel and tinted, and sometimes it's not.  Also seem to see complaints that the price is higher.
Also found an interesting writeup on approach
https://thegoodthebadandtherv.com/2016/04/22/fuel-truck-stop/
Yes.
Taxed and dyed is a different issue.  It's all (now) USLD.
It is illegal to manufacture or sell anything but ULSD in the USA or Canada.
"dyed off-road fuel" is also USLD. The dye just indicates that road tax has not been paid.
The regulations phased in the conversion from  LSD to ULSD -- but the phase-in is complete.  Phase in changed different parts of the market at different times so that all refineries were not 'down' at the same time.
If you see a pump with an LSD sticker it's because somebody overlooked that it needs to be removed or covered up.
You can probably search and find more info about the conversion timing for various markets (road, farm, marine, rail),  but the bottom line is that it's all ULSD now.
Mexico is a different story, if you take your diesel there.
On 7/26/2018 at 10:47 AM, redwngr said:
Why don't you fuel at truck stops?
Lots space to turn and they also cater to large motorhomes camper rigs so clearance heights are definitely not going to be a problem even at the islands with the smaller hose diameters.
(I'm surprised you have found many/any canopies that are not high enough for a legal road height vehicle to pass under, but agree that some car focused lots are very tight for maneuvering a long vehicle....)
I'm like you redwngr.  Neither my wife nor I can go more than 3 or 4 hours without a personal pit stop, so we always stop at truck stops even if we don't pull a trailer.  Many locations have pumps not under a canopy.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
