Antifreeze leak
So update, had it to GM dealer today, they did a pressure test and sure enough its leaking in the upper right of the rad. Parts and labour close to $2100 to replace. Waiting to hear back from Ford dealer (who I bought it from) on how they plan to pay for it, as its not covered under the thermostat coverage or the power train warranty.
Funny, I mentioned to them about the clunky transmission. Was told its acting normal, and that I have "aftermarket parts" on the truck which is making it worse, and GM wouldnt cover any fix anyways. Unsure if the meant the muffler or the intake lol. SO if I need to bring it back in for it, I'll toss the factory tube back on.
I think Powertrain only covers major internal engine components?
That is unfortunate.
Based on the Cycling Thermostat thread, I think it is the dealers discretion unfortunately.
Yeah, I figured it would go this way. Either way, won't be me paying for it.
When I picked up my '14 sierra it came with a Certified Pre-Owned warranty. Then again my truck came from a GMC dealership.
The CPO has been worth its weight in gold. Repairs covered 100% and no deductible.
So far I have had 4 major issues taken care of.
I still have the remainder of the powertrain warranty in case something major goes wrong inside the engine.
actually we almost had a GM PP warranty. Was told it was on the truck, was being transferred from previous owner, only come to find out previous owner lied, actually cashed in the remainder of it and got a payout.
Man, that really placed you In a bind.  Sorry to hear that Rosco!
yeah, it sucked. But it is what it is.
So update, still waiting to have this fixed. Playing phone tag with the Manager at Ford where I bought it. Finally spoke to him yesterday. He's telling me about a TSB that may cover this fix. LOL. You mean the TSB that GM said didnt cover it?? So he's waiting to hear back from GM dealership.
IMO this should have been a 10min conversation between them, and truck fixed. That said, I would rather have it fixed as per the TSB if thats really the issue, so that it doesnt happen again. So I'm not really pressing the matter if he indeed can get it covered under the TSB.
    Matt Parker
    Matt Parker
  • Who's Online   2 Members, 0 Anonymous, 781 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
