DL3 Mirrors Available
Jim14
If anyone is interested in a set of DL3 mirrors I'll sell them for a good price. I just did the tow mirror swap. They are off a 2016 2500HD Denali Diesel 4wd.
Did you add the tow mirrors or are they what you are getting rid of? Sorry I am not sure what the DL3 stands for other than it is a mirror, I know there are a ton of options for the mirrors between models.
He added tow mirrors and removed the DL3s. Those are the non tow mirrors that are power fold with the built in turn signals and puddle lights.
This link shows what they look like. You’d have to ask the OP if they have the extra temp sensor in the passenger side since they came off a Diesel you wouldn’t need it if they do since yours is a gasser. You’ll also need a harness/button upgrade to utilize all the functions of these mirrors if your upgrading from the DL8s (standard non fold mirrors). I would assume these are the mirrors (DL3s) you already have since yours is a LTZ? Maybe not?
 There are several threads on here about this swap and the harness you’ll need.
This thread answers a lot of the mirror questions for you. This is also the go to guy on here for most of the electrical stuff on here and the guy you would want to get a harness from if you needed one.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 193 Guests (See full list)
