OEM keyless
tek6029
Hey guys, I've tried searching and I couldn't find a clear answer... everything I found was for the last ten trucks I think
I just picked up a 2014 Sierra DC base with electric locks but no keyless. I read that if it's got certain RPO codes I can buy key fobs and have a dealer flash them to add keyless entry to me truck.
I called my local GMC dealer, where they transferred me to the parts department, took my VIN and said since there wasn't a kit or part that was compatible with that VIN then I couldn't add it.  Not sure they understood my question.
Any more insight? Or am I going to have to go aftermarket? Thanks!
I believe the Silverado W/T is the same as the Sierra Base?
I'll check out those threads and see if I missed anything, I thought when I looked previously everything I found was on the 2013 and older trucks or 2500 series. Thanks!
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 240 Guests (See full list)
