Front end clunk
Chad2815
2017 Denali that clunks very lighty when the wheels are turned more than about half way. I tried the search but mine is a lil different because I can only hear it at low speeds? Took it to the dealer......shocker I know but they could not duplicate. Now Im on vacation and its driving me nuts. Like always guess I will just get advice on here and then tell them what to do...Thanks in advance guys.
Dont think it would be loud enough, sounds like the steering column on the 2001 Silverado I had that had a recall but it only happens when the wheels are all nearly all the way turned going over uneven terrain.
I would go to Les Schwab and ask them to "shake down" the front end. Its a free service, and they will give you a detailed repair estimate that indicates what the problem is.
I'm guessing that its the sway bar bushings, wheel bearings, shock bushing, ball joint, tie rod, etc.
