Three 1st's and a 5th place
Shaners
Some of you may remember me mentioning that my wife started swimming again this year and that she joined the local YMCA "Masters" swim team.  Today was the first day of the 2-day State meet and in the four events she swam today, she took Three 1st places and a fifth place.
These places are for her age group of 35-39 years old (she is 37).
She swims 5 events tomorrow, and I expect her to bring home at least 2 more "blue" ribbons!!!
I'm very proud of her...  :D
Too bad she is going to kill you for posting her age :D
She isn't self conscious about her age...  especially since she is a mother of three (9,6,3 years old) and can still go out and carry a big can of whoop-a$$!!!   LOL
Congrats are definitely in order :D
LMAO!
Sorry we won't be seeing you on here for a while Shane.  Time to move the new leather chair out to the truck.  :D  ;)
Here is what it was all about...  her specialty is the backstroke.
The start:  (The red suit in the middle)
In the lead:
The end result:
When do you bring home the next set? :D
Not until next year.  Nationals is in Ft Lauderdale in 2 weeks, but I couldn't convince her to fly down there.  She doesn't like to fly, and with it being a 4 day event it would have taken too much vacation time to drive...
It's been a long season...  :D  and it starts again in August for the 02-03 season!!!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
