Looking for a lift kit! Need some insight.
Hey guys first time here. I bought a truck for my wife and she wants a lift and bigger tires. Maybe some 33s at most. Truck is a 2005 Silverado 1500 2wd. It has the 5.3L. I've been looking for some kits. My wife wants a 6 inch or close to it lift. Leave it to the shorties to tower over everyone lol. I saw that rough country has some but I wanna know all my options. Thanks in advanced.
  • 3 weeks later...
are you considering a body lift?  stupid cheap and will definitely clear 33s.  if not, I have had a couple rough country lifts and they work great.  maybe not the smoothest ride but they're usually cheaper.
also, the body lift is super easy to install if you are planning on doing it yourself.  if not, the shop I bought my lift from charged $800 to install a 7.5" suspension lift and $500 to install a body lift for comparison.
I think I settled on the 4.5 from rough country. My wife wants to do off road but nothing crazy. Fire roads or flat ground. Some rocks. I just wanted the lift for some clearance so she wouldn't have trouble keeping up with my new truck
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
