LED Light Bar Wire Routing-Firewall
Mclovin1
Hey! I’m trying to install a LED light bar in the lower grill on my ZR2 using the Baja Designs mounts. Anybody do this before? If so, how’d you route the wiring harness through the firewall?
Thanks!
  • 4 weeks later...
I believe there is a rubber grommet near the steering column that you can cut and pass the harness thru.
I have two sets of light bars, one on the roof and one on the nose.  I didn't like the idea of cutting a hole in the dash for a set of switches and also running two harness wires thru the firewall.  I bought a two channel wireless remote off Amazon to trigger the relays.  Works great, been in service for several months now.  We'll see how battery life goes.
  • 1 year later...
Just did this yesterday on a '18 ZR2.  We went through the hood latch rubber gromet.  We installed a factory headlight switch with the fog button and ran a 22 gauge wire through the gromet to a latching relay since the fog button provides momentary ground.  This means your latching relay needs to be able to trigger on ground.  We did this install for a lightbar and interlocked it with the highbeams, so the lightbar could only run when the brights are on.  Fogs are legal on highways, but lightbars are not in most states.  Use them at your own risk.
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,150 Guests (See full list)
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
