Interior swap
So I know this is a long shot but I have a 2008 gmc 2500 slt and I have a 2017 gmc high country FULL interior. Seats, door panels, carpet, dash ect. Can I make this work? I know I can make the seats and console work but I really want to swap the dash and door panels also. Thanks for any info
The seats would be no problem. Of course the airbags wouldn't work in the seat but I could help you get everything else working. I don't know how well you are at fabrication but there will be some welding needed. If you're really interested in it let me know and I will walk you though getting it started,
I just sent you a private message
On the seats the only part that would need fabrication is the front hold down hooks on the 2017 would need to be cut off and the bracket for bolting down the 2008 seat would need to be removed and then welded into place on the 2017. I would remove the carpet, cut the hooks off the 2017 and set the seat in. Mark or spot weld the 2008 seat bracket into place and then remove the seat. Get a good weld and reinstall the carpet. Then install the seat. Let me know when you have that done and I will get you the wiring schematics for both so we can go through getting the power seat part working.
  • 3 weeks later...
  • 1 year later...
    ar0517
    ar0517
  • Who's Online   5 Members, 0 Anonymous, 660 Guests (See full list)
