Mirror question
So my 2015 has the towing mirrors on it.  I've read and researched the one mirror brighter than the other issues and found something out.  The driver side mirror has the led signal lights, but with an opaque cover over the bulbs to make it not so bright.  The passenger side mirror has nothing covering the led signal lights so they are brighter because there is nothing to dim them down.  However, I have noticed that the new, at least new on the lots now, the mirrors are the same on both sides.  the signal leds are not covered, and should be same brightness from side to side.  With that being said, I wonder if the MIRROR GLASS part numbers would be similar or if one supercedes the other if someone wanted to get a replacement mirror glass?  Anybody know?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
