Roll bar and Bed Cover?
I really want a light bar like the one pictured below. Issue is I have a hard roll up bed cover that sits on the bed rails. Has anyone found a roll bar that will work with a bed cover?
Im thinking I will have to have one custom made. Wish I had access to a pipe bender.
I would have to see a picture of your bar sitting on the rails as well. I have the GM bar with the All Terrain X package and have a soft roll Truxedo LoProQT which works fine! But the cover doesn’t actually sit on the rails, it mounts inside and is flush with the sides
hmm... to bad I already have the hard cover. I have gone with the Truxedo soft on other truck and decided to go for the hard cover. it rolls up into a can type thing and thus sits on the edge of the rails to support the weight. It does not sit inside. Would need to double check but I say its about half an inch onto the rails.
Here's the thread you should read about the same issue.
You have some options, but you may not like having to buy a new cover.
I think it will be noticeably cheaper to just make a roll bar then replace the $1200 bed cover. Plus, I really like this roll up hard cover. That roll bar is only 2 tubes with 8 bends.  You could remove 2 of the bends and just angle cut the base of the rear bars. The flat plates are very easy. Worse case I would have to notch and gusset the bars to fit around the cover.
If you have a metal shop, you can definitely make your own. There was a guy on here that made an awesome looking headache bar /light rack by himself. I can't find his post now. Searching on this site is a joke. I can't find it using google either.
But we all love pictures of do-it-yourself projects so let us know what you end up doing!
Only issue is I dont have a tubing bender.... trying to find a shop that will do that part. The rest I can do. I'm more into suspension stuff like 4 link, full air ride rather then accent stuff. I will update with some pictures.
My V8 Swapped B2200, GM 10 bolt, 10 shot, Gear Vender Over drive, TH350 full air ride on parallel bars.
    FiLo
    FiLo
  • Who's Online   4 Members, 1 Anonymous, 589 Guests (See full list)
