4.3 Vin W - Crank No Start
Have a 95 S10 Vin W 4.3L Vortec in a 1950 Willys CJ3A,
started as losing power and stalling under load (plowing).
That went on for a couple of minutes and now no start at all.
Conversion was done complete with computer, but have no manuals.
Have not checked the distributor yet to confirm no mechanical problem,
but have no spark. Is there any thing to check between the distributor and
the ignition coil?
Does any one have any testing information or other insights?
Thanks, Bill
  • 1 month later...
Here is a schematic of the distributor, there should be a pigtail in the harness, when you crank the motor, it should pulse when cranking.
If a solid light, the ignition module is not getting a crank signal.  Then you will have to check the resistance in the pickup coil. Value should be 900 to 1100 ohms, if not, replace the pickup. If there is that resistance, replace the ignition module with a "factory replacement" Delco, not an aftermarket. Also it's imperative you clean the 2 grounding screws for the ignition module. They are the ground points for the module. If you get "any" silicone paste on those screws, the module will act like it failed.
See the source image
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
