Unplug your your passenger seat and inspect the body side connector. If you have the power and ground circuits, you should be ok.
This pic is for the driver side, but passenger side has the same power/ground locations.
Would we be able to add the power and ground circuits if they aren't present?
Ok so I have the regular power drivers seat on my 18 Silverado 1500 but I have a new passenger seat track from my 2017 Silverado ltz, would I be able to use that track with a set of switches on 2018 passenger seat if I have the power and ground ? Will it work ?
Sent from my SM-N950U1 using Tapatalk
You have the entire seat itself or just the track?
If you inspect the connector that your seat plugs into and see if you have the power and ground connections.
This is the driver side, but the passenger side has the same power and ground positions.
I will attempt and let you know
  • 10 months later...
On 12/5/2018 at 9:41 PM, pgamboa said:
Don’t lose hope...
For the airbag light, I think this might be related to the release years. I think with 2016+ seats, you won’t need to worry about the seat position sensor.
Easiest method is to try to source seats that did not come from a seat memory truck.
If you find a deal on memory seats, still not the end of the world. You’ll just need memory bypass harness from me.
I just wanted to state full disclosure to understand all the gotchas with this.
I bought seats out of a 2017 ltz (or That was what I was told Anyway) To put in my 2014 lt. passenger seat was manual and new one is automatic. Seat functions all work but airbag light is one and is saying seat position sensor. I need your harness for this and driver seat doesn’t work at all I assume it’s related to the seat memory module. Is it $150 for both or just the driver seat harness fix?
Please note the closure notice on the site. You can place your order online and we will build/ship all products in the order they were placed when we resume normal operations.
You need one of each. You’ll need to remove the seat position sensor from your factory passenger seat over to the new passenger seat.
https://harnessdr.com/product/2014-2019-silverado-sierra-seat-memory-bypass-harness/
https://harnessdr.com/product/2014-2019-silverado-sierra-seat-position-sensor-harness/
@pgamboa so if I understand this correct. so long as i have the power and ground circuits pictured on the passenger side, can find a power non-memory passenger seat this is a plug and play swap?
[mention=159655]pgamboa[/mention] so if I understand this correct. so long as i have the power and ground circuits pictured on the passenger side, can find a power non-memory passenger seat this is a plug and play swap?
Yes. There is no passenger seat memory... just driver side.
I have a 2018 Silverado with cloth seats ,was wondering if I can buy track seat for my passenger side to raise up and down so my daughter can see better ,of course it’s lifted
What is the easiest way to add a passenger side power seat to a 2017 Silverado 2500HD. The driver is power with no memory. I have not dug into the wiring yet. Like someone else was saying can I just use the power seat track from (what  year) and put on my truck? The truck has 14,000 miles and seats are great. Problem is short wife doesn't like staring at the dash or hood. Can't raise seat because 6' son wouldn't be happy. (Please note changing out wife is not an option.)
What if I can’t find a seat position sensor to plug in on my stock seat or on the new leather powered seat
    67elco
    67elco
  • Who's Online   0 Members, 0 Anonymous, 1,294 Guests (See full list)
