RC/Zone Lift Kit
Now I want to be the first to say you get what you pay for. That said, im really wanting to put a small "lift" on my truck specifically nothing more than 3 inches. Ive been modding my truck and I feel like the last thing to do to it is lift it. RC offers a "3" inch which includes shocks, uca's and the blocks. Zone offers a similar set up for about the same. So is Zone quality way better than RC? Any of you guys running either or or know anybody running it. Reviews seem positive for both. Considering my truck is a 2WD, I dont have to worry about CV angles but how much should I worry for other things. Lastly would it be difficult to get it aligned or does it just depend?
Heres the RC kit: https://www.roughcountry.com/gm-suspension-lift-kit-8596c.html?gclid=CjwKCAiAjNjgBRAgEiwAGLlf2kdT5efE-SdLmnRoUdi53r27eUYxRJqvZpSB9UXP3pUtLLRIFZD89BoCt_IQAvD_BwE
Zone:http://zoneoffroad.com/zone-offroad-products-2in-suspension-lift-kit-chevy-gmc-pickup/c1212-c1213
    bellssn690
    bellssn690
  • Who's Online   5 Members, 0 Anonymous, 718 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
