Flashing check engine light
Erok
Need help. I have a 2014 Sierra 5.3l. Every so often the check engine light starts to flash and then goes away. I always shut off the truck for a few then get back on my way. The last scan I did came up with p0305 misfire. I have replaced all the plugs and wires last year and just did all the coils last week.  Now the damn light came back on. I have no clue what it could be or what I need to do to fix this problem. Any help would be greatly appreciated. Thanks
I would have it checked out, you have a problem with the emissions somewhere. Could even be a lifter sticking, camshaft sensor going out, etc..
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 1,404 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
