2nd Row Screen Not Working Correctly
Hi,
Anybody seen this problem? 2nd row screen works intermittently. 3rd row screen is fine. Feels like the switch or contact that shuts it off when being closed isn't working right.
Thanks,
  • 3 months later...
  • 4 months later...
I had my entire middle row unit replaced 15 months ago (4 months after I bought it). Got into an accident last month and it quit working again. They say it isn't from the accident, but I find it odd that it just quit right after! I'm going to attempt to fix this myself, wish me luck! GM should really do something about this, definitely defective! I will never buy another GM again! What a lemon! I won't even get into the other 6 repairs in the first 7 months.... luckily was still under warranty then.
