How To Test Batteries/ Battery Info
diyer2
I believe the batteries in today's modern vehicles are way more important than years ago. Today's computer controlled vehicles are more sensitive to voltage fluctuations, especially low voltage IMO.
A good battery is essential to keep voltages within the designed voltage range so the electronics perform as engineered. All solid state electronics have a designed operating voltage range.
A good battery is cheap insurance to have a properly running, reliable starting vehicle.
Those of you that know me have seen my posts about replacing my batteries every 4 years to avoid dead batteries. Not only does this avoid a vehicle failing to start but it also ensures proper voltages for the electronics.
This web site has a lot of info if you want to learn about batteries.
https://www.autobatteries.com/en-us/battery-testing-and-maintenance/car-battery-voltage-and-testing
I have had a solar powered  second home for 20 years and the batteries are the heart of the system.
To properly check the charge of a wet cell lead acid battery(you add water to these type) you should check the specific gravity using a temperature compensated hydrometer like this.
This instrument is the best way to test the charge status of a wet cell battery IMO.
4c85532cb2f166ae7d84a951868afb6a?AccessKeyId=076BE662D6DB3268D410&disposition=0&alloworigin=1
This instrument can find bad cells in a battery.
Available here https://www.bradyinstruments.com/wall-mount-system.html
    todd wollemann
    todd wollemann
  • Who's Online   0 Members, 0 Anonymous, 451 Guests (See full list)
