AM radio not working
GC Clark
My FM and AM radio reception went out. I could only get 1 FM channel. I popped the yellow fuse out on the passenger side panel fuses and put it back in. The FM started receiving channels but I still cannot receive any AM channels. What else can I try. My truck is a 2016 Silverado 2500
On my 15 there is an option in the radio settings to update the station list. I'm not sure if that pertains only to satellite radio or all radio stations. But it's worth a shot.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,344 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
