Gibson exhaust
Anyone running this setup as a true dual exhaust?? I bet this would sound awesome! I listened to the sound clip and liked it. Curious how a true dual would sound.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 201 Guests (See full list)
