Today was the day.
The SPEEDY
Toyota finally gave out today. Speedo broke about a year ago, and the odometer reads 316,xxx miles.
Got home from school today, and I had steam comming out the exhaust. So 1 of 3 things: Blown head gasket, cracked head, warpped head. My dad doesn't think I can fix it (I think/hope it's the head gasket), but I am pretty d**n sure I can. What would it hurt any way?
So now the search begins. I was hopeing the car would run a little longer so I could save more money for a new car. :D I will finally belong here though because I'm sure as hell getting a GM (can't say it will be a truck though).
Getting rides to work and school sucks BTW.
I said before to drive the yoda till it blew up, but MAN, I did not mean to wish it on ya now! :D
Good luck finding a new ride! Bummin rides sure does suck! :rolleyes:
Found any of the rides in your sig yet that you can afford now?
Thats why I'm upset about it. I'm still a few grand off from those, and have nothing to drive. :D To bad my brother is home now or I could drive the ford. <---Man am I desperate.
I told myself a long time ago I wasn't going to spend my money on something I wouldn't like latter down the road. So I hust bum rides for now.
For the right price, I would drop a 427...stroked....bored...blown....You could do some wheelies in it...
Only an extra 10 grand. :D
Oh yea getting a ride to school SUCKS. I had to do that when I had to replcae my flywheel. :) Luckily I had a friend that I gave a ride to when his clutch was out.
Wingnut. I could be happy with a 92 Blazer. My wallet couldn't right now though. :sigh:
Agreed, bumming rides does suck.
I could get you a Regal or Camaro for a good price, the only problem is that they are about 25 years old and sitting in a field in Alabama, and the Regal may have a bullet hole here and there...
Looks good, and 101k miles is not that bad. My dads old 72 GMC had a 305 TPI that the previous owner put in. Good little engine
How about a used Geo / Chevy Prizm for about 3-4K? I have a buddy at work that is selling his '99 Prizm with about 100K for about $3300 later this fall.
I've done the slow econo car thingy.  Just blew it up yesterday.
As far as that car goes Speedy, I would say that he has added just enough aftermarket performance stuff to make a 140k mile motor a big headache for someone else.
His price is a lot more realistic though.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
