Question: 33 x 12.50 x 20 fitment
wh1skey6
I have a set of XD800s I got from my cousin's rig that I'm thinking I want to put on my 2018 Denali 1500. They have 33x12.5x20 on them now. Wheels are 0 offset.
Questions:
1) Will I rub with this combo without leveling in the front?
2) They were off a Tacoma. TPMS are not cross compatible across manufacturers, right? (I have the TPMS reset tool but haven't tried)
3) Is there a stock equivalent tire size that I can ask the dealership to flash my computer to calibrate the speedo?
I checked a few online offset calculators and it looks like it should be ok (may push out a bit).
I run 305/55R20 (33.2"x12") tires on a 0 offset rim and I have 2" level and I just barely rub at full lock ONLY when backing up. I don't see a way for those tires to work on a stock suspension setup. Don't know the answer on questions 2 and 3 though.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 270 Guests (See full list)
