Bump stops
A negative amount.  They should be slightly compressed against the LCA.  They aren't only "bump stops", but are part of the suspension, and assist with how the front end works.
Thanks. Davester.   I've been getting all sorts of information, some said just a tiny bit touching all the way to an inch of space between the stop and the LCA .  When I finally put them on I think it will compress about a 1/2" or so.  I'm going to put new shocks on at the same time.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
